本文章最後由 snow12684 於 2012-2-29 02:55 編輯 , v6 \* J5 v4 v) b4 |% J1 X
General #16406. r% W m3 P! U& `! Q; g
( S" [3 Y$ N" Z1 u, I9 W# \$ G" [, } Complete name : D:\HD.Club\Rainbow - Gonna Gonna Go! PV(SSTV HD).ts
& s; B6 u) h& v1 D; b/ B/ e5 d3 K Format : MPEG-TS8 a* v) i y5 }* T8 F# K
File size : 235 MiB: w1 i7 V( \0 ~( z( n0 e+ Z
Duration : 3mn 59s
5 z3 r5 j3 f' Q. r; j3 T# M) X Start time : UTC 2012-02-28 07:36:35
3 U/ ?2 m2 N+ O' [; B# `9 F End time : UTC 2012-02-28 07:40:35
V* ?/ d d4 y7 a Overall bit rate mode : Variable
. e5 d# Q6 W) G! I Overall bit rate : 8 183 Kbps# `' |: t7 X/ f* I
Network name : |鼠欴!D齾?0 C0 ]6 j0 k& O- a6 M* i
Original network name : Astra 83 D4 B! c8 n/ z/ e/ J
Video #4101
* A( R8 }* s* v0 K- e5 { ID : 4101 (0x1005)' S; x, `" P) B! X
Menu ID : 33410 (0x8282)
& R7 f, p8 O; X" p Format : AVC. a: u! i9 p1 J2 G+ w, X3 N
Format/Info : Advanced Video Codec+ _+ n+ D9 w/ x/ z3 U
Format profile : [email protected]/ c* b% } D% a, y5 y6 B0 L; o
Format settings, CABAC : Yes% T7 N: a$ w) m& R# f# l
Format settings, ReFrames : 4 frames
5 M! W0 w# y$ Z' a0 X8 T0 X/ h Format settings, GOP : M=4, N=281 f4 B( c+ |- [- M
Codec ID : 271 M0 i1 p2 d V5 i* S
Duration : 4mn 0s
4 }) N$ J% \1 ^3 r7 ^ Bit rate mode : Variable
3 }7 c& D5 k, U$ m: w Bit rate : 7 633 Kbps
7 [ ?( D( S( s! s; T9 i7 @ Maximum bit rate : 20.0 Mbps
0 t8 X. f6 v( x* o6 n' Y' O9 j Width : 1 440 pixels0 F+ n- m/ t* d! j
Height : 1 080 pixels+ {1 d' J* h4 f
Display aspect ratio : 16:9
% K% i+ N) W1 o, E1 p! d' D3 A h# j8 \ Frame rate : 29.970 fps% A6 V. K6 P8 j
Standard : Component
! R* ?3 T8 }5 _% q) W4 j, H& v Color space : YUV
# j" K! R0 `2 n; \' ~ Chroma subsampling : 4:2:0, k: h- s" I5 m5 B% J
Bit depth : 8 bits
$ }+ a- _: {& F( u/ J Scan type : Interlaced
1 a x, u! `9 W! X Scan order : Top Field First
/ X) ?: h6 w7 q& y% v! @ Bits/(Pixel*Frame) : 0.164. S1 k+ [$ m; h: S1 j" N
Stream size : 218 MiB (93%)
% h: w" U5 E; f) r Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
h$ e3 |% j0 _! V0 J Transfer characteristics : BT.709-5, BT.1361
) N5 c" e2 o+ X0 L, f0 e Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
! f: B& @5 e( A7 K: w" E+ |- q+ } Audio #41654 z- E0 |! T) t$ X" q
" k/ h4 @* Q) N7 K* C Menu ID : 33410 (0x8282)+ ?, ]' e" ?. Q
Format : AAC
- X4 ~" @" ~& Y, ~: S2 J# R5 U Format/Info : Advanced Audio Codec' r# v g9 r% e
Format version : Version 20 x* R3 ]0 y1 o
Format profile : LC
/ b; ]; Y6 e* H4 e5 n- @ Muxing mode : ADTS
( P2 d D8 l' v' A+ e& a Codec ID : 15
1 d4 x( ?6 w/ |2 p2 @ Duration : 3mn 59s
9 w$ s, y9 ?1 e; Y% G Bit rate mode : Constant
/ ?! S" t& j$ o3 m Bit rate : 144 Kbps
" Y) _3 @* _" F% }. | Channel(s) : 2 channels* m+ j' [6 g4 U& {
Channel positions : Front: L R
7 i* @/ u' [( q Sampling rate : 48.0 KHz
4 N; k3 o) M, Z3 t* o' g& w% h Compression mode : Lossy
6 z3 @8 h8 }4 `: \( a6 R Delay relative to video : -6ms
: d8 T+ k& `' W- o& F I Stream size : 4.12 MiB (2%)
% M9 E" \6 N9 {6 ?7 c$ D! h: P1 m5 |$ X" S# R
& R# a: v) ?5 F! E
% W8 T, K- V! T# z
0 s7 W/ H- o+ G3 S' c% Z. h4 R
5 D3 M2 C, W, @. n) C4 `" b, N% v
! A: |) M- d8 P
2 m! ]! ?; N: X; v
- Q' k( a; E1 W& N2 W) g$ t
Link.rar
(209 Bytes, 下載次數: 235)
0 D0 H) s0 m8 h- t8 q5 z
( O; _5 Z: ?# n2 v C
/ b# f; t8 ^8 ]* X" @3 A
1 t# ~; w: A" x. C& S) I0 v1 I
; j7 Y4 ]) M+ M: b; o3 X' [ |
